Thanks Garbone and Blltrdr,
Gear Box side clutch adjustment, already tried out and did not solve the issue, going to check the clutch pack, i hope its as easy to put it back as to take it off, little hesitant.
Blltrdr - changed the timing back to be in the middle, air screw 1.5 out, ping time ?
Is there a way to check if the Breather is working correctly ?
Manual says..
"If the breather is not acting efficiently it may cause pressure in the crankcase
instead of partial vacuum, giving rise to smoking or oiling of the plug."[/b]
It looks like, its not going to be a quick fix, I am glad to be hear talking about all of this.
Thanks again for the pointers.
First goal will be to get it to run, take it to at least 60-75mph, so i can get it out
beyond the subdivision roads
, actually if i can't fix it, will enjoy that idle in the driveway!! love the thumper !
