I am about half way through the conversion from left to right foot shift and have run into some problems. I asked a few questions at the yahoo site without any success. I have been following the Snidal manual and Here is my problem:
I've moved on from the detent plunger assembly to the ratchet assembly and
I found that when assembled there is alot of play of the Ratchet outer/FC plate
(63 and 62)and the adjuster plate (57). So much play that the F/C ratchet
spring (59)has enough room to slip off the spring stop (58)on the adjuster plate
(57). Is this too much play? I would think that one "ear" of the ratchet spring
(59) should be in contact with the spring stop (58) at all times. Is this true?
After looking at the gearbox for a few days I think the problem started when I installed the bush (part 44) for the "bell crank" lever (46). According to the Snidal manual, this bush should be pressed in until it is flush with inside of the inner cover. In fact, after looking at the original inner cover for the left foot shifter, this bush should extend approx 2mm into the gearbox side of the inner cover. The lack of the this extra 2mm is causing the play in the ratchet assembly which inturn is causing the F/C ratchet spring (59) to slip off the spring stop (58).
One other problem is that outer cover hole where the neutral finder shaft extend through is misaligned and will need some grinding to enlarge the hole.
Anyone done the right foot shifter conversion and give me any tips?
