i've posted about this before but here we go again. i have a 2002 enfield w/4 speed. i converted it back to right side shift. while placing the inner cover on and off i accidentally removed the lay shaft. after a few tries i believe i have it back in correctly. however. i cannot shift to second gear while riding. if i have the back wheel off the ground i can shift it through the gears with the neutral finder but not the shifter arm. does anyone have any suggestions? i know it sounds crazy but i have about 30 hrs or so into this and i'm about done with it. i know this would be simple for someone who knows transmissions but, i unfortunatley don't. i'm tempted to pull the entire trans and send it to a dealer (i don't have one close) to have them fix it. if anyone lives in the philly area and has any experience with this type of thing or knows a mechanic that would work on the bike, i'd appreciate the help.
