They tend to run a bit rough when they are new. Just keep riding it for several hundred miles and it will smooth out and the idling will stabilize. As for the plug, replace it with an NGK BPR6ES for about $3.50 and that will help smooth it out. Replacing the stock muffler with just about anything will help, too, and a K&N filter flows a little more air if you don't over oil it.
But basically, just keep riding it and let it get broken in, that will do more for it than anything else. Except maybe the spark plug.
Do change the oil at about 300 miles, though.
