The clutch is located behind the left cover, so there will be oil. I'm not sure if it's necessary to drain completely though, but as it's 2L as maximum just put a big pot underneath, maybe you can save some oil this way. Don't forget either to get a new gasket first, or to be very carefull to preserve the old one.
Concerning the noise: another possible origin is the clutch, f.e. a broken spring or plate. In this case switching gears would be impaired, or clutchb drag would occure. Anyway, most failures should be quite obvious. Good luck & regards
