Ok, so about a year ago I bought a 2006 Royal Enfield Bullet 500cc Military.
And wow, what a eye catcher. The bike came in the shop I work at to have the starter fixed. It had set a while and the owner couldnt get it to start. Hes the kind of guy who buys a 5-8 bikes a year rides a few months and sells them. So when he got the quote to pull the whole primary and starter drive system, he approached me to sell the bike. I had couple hundred stashed away, not the $1000 he wanted. (hell of a deal less than 3000 miles and fairly clean) So I offered the cash I had an to make payments. He accepted! SO after about 8 weeks of top romin noodles and pb and j sandwiches i had a new bike. After fixing a broken rear spoke, adjusting the breaks, checking points gap, cleaned the carb, oil change, added a fuel filter and replacing a few clutch cables I have the bike in tip top shape for the road. I ended up useing a Honda gold wing cable to alleviate the chaffing on the inner part of the lever that kept causing failure.
The bike seemingly has two mods. One being a cone style filter, with the PCV system routed through a hose ending at the chain. Secondly the muffler is either de-baffled or a short euro system. The bike definatly sounds louder than any stock single I've heard. Id say 80db.
When I first got the bike it was a little hard to start, but after getting it running and cleaning the carb it kicks over 2nd or 3rd try. No choke needed which is odd IMO.
Now the problem
The bike idles great, and goes down the road decent. Good fuel economy and no problems, EXCEPT when at a low throttle cruse. If you wrap the throttle, it has a hiccup or a slight hesitation than fires to life and accelerates hard. While in neutral if the throttle is opened to 100% off idle, it will bog and totally die. But, if you are just a hair over tickover speed, say 10% over idle, the engine accelerates beautifully.
Sounds to me like a lean condition. So, I opened the carb back up, and I installed a 125 jet. The jet that was in the carb when i got it was a 120. So, after starting the bike and warming up, following the standard method to adjust the low speed air screw and idle, the bike still runs the same. Than I thought, maybe ill check the needle. It was set one slot above the bottom. So, i figure maybe try putting the needle towards the middle, 3rd up from bottom and the 115 jet, with smaller idle jet at 25 (had 27.5) Well, this created an obvious bog at low speed cruse, with the same issue in neutral. Figuring that since its worse, and that after restricting the air flow with my hand over the carb it reved well, I put the biggest Jet i have in the bike(130), than dropped the needle clip to the bottom, installed the bigger idle jet. Now the bike starts the same, and of course I tuned the low spead accordingly with each jet change. But it still has the problem bogging in neutral, and a light hesitation on fully open throttle at low rpms.
My biggest problem is I have no idea what the stock jet size is. I have the owner/service manual but it doesnt give stock specs for carb jetting. I cant find info in the internet either. It has the Mikcarb vm28.
I think i just need to tune it richer. Tommorow im going to drive the bike a bit more than normal, and check my plug with the current tune. The plug originally showed signs of a lean mixture but not bad. The other odd thing is that when I pull the choke it dies. It doesnt matter if its cold or warm or anything. The bike will run on choke, if you increase the idle but it doesnt seem to run better and is slightly restricted in the top end.
Anyway I tend to go on and on, but hopefully someone can at least chime in about the stock jet sizes.
Thanks, Sean
