Street,
Be VERY careful with trouble shooting the issue when messing with the amount of oil in the system. Your engine has a warranty on it, but if you run that mill without enough oil and you make it grenade on you, you may be up the creek without a paddle.
When you changed your oil did you also remove the pick up tube screen to clean that out?
Oil exiting the case at higher RPMs is very indicative of oil pressure issues not just an issue with improper oil level.
As a maintenance guy, the first thing I would check would be for excessive pressure in the oil system somewhere. Baring that I would look for a defective seal or sealing surface.
You said that your airfilter was completely soaked in oil. You would have to be dealing with so excessive crank case pressure or a waaaay overfilled engine to be getting enough oil in your airbox through your vent tube to soack your airfilter.
Thanks for the feedback Chief.
Yeah I'm cleaning the tube screen at every oil change, aside from the first change that screen has been clean each time I took it out to inspect, but cleaned it anyway.
With 1.45L of oil in her the blow out through the air filter is substantial.
The first time it happened, I took it on the highway for one intersection, just enough to get it over 100kph for a couple seconds, and then pulled off the highway.
When I pulled off to stop at a light the rear end was soaked in oil, I pulled over and watched the bike drip a large puddle of oil on the ground within seconds.
All coming out of the airbox.
I figured it was too much oil and reduced to 1.4L, but still seems to do it.
Same thing happened this weekend on Sunday, with a fresh oil change in the morning and 1.4L in her.
I have taken it up to 100kph on a few occasions and held it at that speed for a few miles, and not had a problem, but didn't stop or slow down much and just kept cruising at 80kph without issue.
It could be may perspective is skewed, but it seems coincidental that it always happens when I take it up to 110kph for a short amount of time and then fairly quickly am coming down in speed, due to traffic or getting off speed way.
At that point I see all the oil, which wasn't there while riding with me quickly looking down on occasion to check.
