Author Topic: low fuel light stays on?  (Read 13614 times)
prof_stack
Reply #30 on: November 11, 2011, 03:21:59 am
And stack and I are close by, Portland and Seattle.  We probably have similar gas suppliers.
I've been using non-ethanol fuel for about 9 months.  Portland might have some stations.  They are more common in rural areas, but perhaps Oregon is more strict about it.
Reply #31 on: November 11, 2011, 03:45:13 am
The closest ones to me are too far away to be convenient.
Reply #32 on: November 19, 2011, 10:35:14 pm
I spoke to Kevin on this.  There were some problems with the early units and they were redesigned.  The float actually going bad and not floating like mine is not a common failure.
eggman65
  • REV THAT THING!
Reply #33 on: February 13, 2012, 08:15:38 pm
update: had my dealer replace the sensor and it appears (so far) that the new part has solved the matter.
2011 Ural Tourist (sidecar rig)
2010 Royal Enfield C5 Classic
2007 Kawasaki Ninja 250R
2003 Harley Davidson 883R
2002 Yamaha Vstar Classic
1985 Honda CMX250 Rebel
1984 Honda ATC 200s
1983 Kawasaki KZ440 LTD
1980 Honda CX500 Custom
1973 Honda CB450 k6 (café racer)
kingrock
  • 2010 c5 military/ The green Goddess
Reply #34 on: March 21, 2012, 01:45:43 am
Mine crapped out too. After reading all these fixes I made a decision. Use a sharpie and color in the little gas pump. No light no problem.
Reply #35 on: March 21, 2012, 01:59:51 am
I probably mentioned this in another post but my fuel level sensor quit working too.
This is on a 2011 model that I've had for 10 months.
Mine never turns on any more.
Checking at the wiring connector power is being supplied to the switch when the key is on and the downstream wire to the light shows that everything is connected with just a few ohms of resistance which I think represents the light bulb.
I would have to ride about 20 miles to a repair shop and no telling how long it would take them to replace the switch so, for right now, I'll just rely on my Sharpie permanent marker to keep track of the mileage and ride on. :)
aziai79
Reply #36 on: March 21, 2012, 02:29:19 am
Funny Arizoni because I have a G5 deluxe that I bought in early December and my fuel light stopped working too last week...I found out when I pretty much ran out of gas during a long ride (several electrical problems in the three or so months I've had it...speedometer didn't work at outset, Neutral indicator crapped out, and now fuel light). Waiting for dealer to get part and then I'm getting it replaced...should be later this week.
-aziai79
GlennF
Reply #37 on: March 21, 2012, 02:50:25 am
Writing the km with felt tip marker on the chrome handlebar yolk whenever you top up is a very relaible fuel gauge.
Reply #38 on: March 21, 2012, 05:13:49 am
I usually shoot for about 150 miles between refills.
That ends up costing me about 2 gallons worth and gives me another gallon in the tank for an additional 70+ miles range for those times when a filling station isn't available.
Besides that, on a long ride, my butt wants a break after 150 miles of riding.   ;D
