Too bad we can't use a domed (hemi) piston like I have on my Triumph.9.5 :1 compression stock11:1 compression availableWhat's the compression ration on the flat top pistons you are talking about?
I understand.Compression ratios that high might very well bring down unwanted governmental scrutiny.Nobody wants that.
Then I'll start tonight! I don't have a piston or gasket but I have beers!Scott
Have fun with that Scotty! You, Scooter Bob, are my new hero!And I tell ya, once that 2 year warranty runs out, I'll have to look into some of this hot-rod EFI Bullet stuff - love it!
Great stuff here! I had no idea the stock efi piston was dished!
Why S.B., I am detecting a slight rebellious streak in you.Keep it up! .Robert & REnfield.
OK, so the flat top AVL piston will fit in the UCE? Since it sounds like you have done this little modification, what differences in performance did you notice? Did you have to adjust timing or play with the computer's set up?
