Check and make sure the neutral light is on and it's not in gear, and the other switches that control starting are in their proper position. With the experiences with other machines that have an ECU it, my next trick would be to disconnect the battery, pulling your fuses should suffice.That will reboot the ECU and refresh the programming back to zero. Put the fuses back in, then try the starting sequence again. If the proper lights come on, you should be in business. If not, then we have to dig deeper. But I suspect is in the ECU, if it's not in the first lot of switches, the clutch switch, kill switch, Neutral switch, or side stand switch.
