There are many reports of parts falling off RE Bullets when riding, such as foot rests, locks, turn signals and lights ............ My G5 did something quite unexpected while I was riding today. Everything was working fine including speedometer. A few miles down the road during which it had its share of our bumpy roads as usual, the speedometer needle read only 0 ! As I looked at the front wheel, there was this dangling speedo cable sleeve. The nut must have loosened due to its notorious vibrations and completely come off the speedo hub drive. The flexible rotating shaft had slipped out of the sleeve and fallen somewhere on the road way back.
I turned around, rode for a couple of miles looking on the roads to see if I could find it - but no luck. Initially, I was a bit disappointed but soon felt a sense of freedom that I do not need to look at the speedometer at all to see how fast it is going - it was good enough to know which gear I am in and listen to the sound of engine
From now on I think I need to use Blue Locktite on the new cable nut, when or
if I install it. Wonder who else lost speedo cable !
