Like Scotty said DO NOT !! touch that throttle stop screw ! You WILL regret it if you do. If you have a TPS reading of .67 with key on I doubt it's causing any surging, while your under way. .67 is on the rich side of things to begin with. Playing with the throttle stop WILL cause surging. If you have.....there may be your problem. Surging and bucking can come from a lot of different things, I would NOT go right to the TPS adjustment. How's your plug and wire?... How is your ground strap at the battery ?..... Does your mil light stay on?..... any trouble codes when you ground the ECU test wire?..... How is your fuel, old any water in it?.... Etc.
