Home
Search
Calendar
Login
Register
Login
Register
Link 1
Link 2
Link 3
Link 4
Link 5
Unofficial Royal Enfield Community Forum
Royal Enfield Motorcycles
Bullet with the UCE engine
Call Me Crazy...
Login
Register
HITCHCOCKS SUPER BLACK FRIDAY EVENT
22nd NOVEMBER UNTIL MIDNIGHT 26th NOVEMBER UK TIME
SHOP NOW
10% OFF
EVERYTHING
« previous
next »
Print
Pages: [
1
2
3
All
Go Down
Author
Topic: Call Me Crazy... (Read 6402 times)
Chiefharlock
Bulleteer
Call Me Crazy...
on:
October 09, 2011, 04:27:08 am
....You can call me crazy if you like, but I think it would be totally rad if RE put out a 6 speed...
Logged
Ton Up!
prof_stack
Grand Gearhead
Ride carefully - You are invisible.
Re: Call Me Crazy...
Reply #1 on:
October 09, 2011, 06:02:13 am
Okay, you're crazy!
I think the 5-speed matches the UCE power very nicely.
Logged
Chiefharlock
Bulleteer
Reply #2 on:
October 09, 2011, 01:59:48 pm
I'm not saying it doesn't, but there is def room there for either a longer 5th gear or a 6th gear.
Logged
Ton Up!
Chris-G5
Bulleteer
Reply #3 on:
October 09, 2011, 05:08:04 pm
A sixth gear would be nice.
Logged
Desi Bike
Grand Gearhead
Reply #4 on:
October 09, 2011, 05:13:47 pm
Yes... We could always use access to another false neutral.. Haha.. Fifth gear is already a 1:1 ratio I think, we'd have to have an overdrive ratio for a sixth. The current ratios seem to fit well with the bikes and what they were built to do.
Logged
میں نہیں چاہتا کہ ایک اچار
Maturin
Grand Gearhead
My Precious
Reply #5 on:
October 09, 2011, 07:54:36 pm
Which weakness shall be cured by implementing a sixth, Br. Chiefharlock?
Logged
2010 G5
Walter Röhrl
Grand Gearhead
"But it's a dry heat here in Arizona
Reply #6 on:
October 09, 2011, 10:32:20 pm
For highway use a overdrive 6th gear might be nice but if 6th gear was left at a 1:1 ratio and they reduced the change in ratios between 1st and 6th it would IMO be unnecessary.
Those close ratio gearboxes are nice for "peaky" engines which must be kept in a very narrow range of RPM but IMO the Royal Enfield with its high torque spread over a wide range of engine speeds really doesn't need it.
Logged
Chiefharlock
Bulleteer
Reply #7 on:
October 09, 2011, 11:01:23 pm
An over drive for the highway where you are doing over 55-60 would be great. Its just an observation I have made over the past couple of days of rolling through Missouri's stretches of Rte 66 and in and around Osage Beach.
Logged
Ton Up!
Grand Gearhead
Reply #8 on:
October 10, 2011, 01:21:19 am
Just put an 18 tooth sprocket on it. That would have the same effect.
Logged
Hypercafienated
Grand Gearhead
Ride In Paradise Cabo, Don and Ernie
Reply #9 on:
October 10, 2011, 02:06:38 am
I would like a wide ratio transmission gear set designed to compliment the 18 or 19 tooth drive sprocket.
Such a set up would give the same final drive ratio in first as stock.
Second through fourth wold be spaced appropriately and top would be 1:1
Logged
FiRE Comms
Bulleteer
'11 C5
Reply #10 on:
October 10, 2011, 02:29:55 am
will the 18 tooth fit on the c5 w/ kicker?
Logged
Chris
Hypercafienated
Grand Gearhead
Reply #11 on:
October 10, 2011, 04:21:50 am
IIRC 18 tooth is standard on the C5.
In a nut shell a 19 T should
roughly
do for a C5 with its 18" wheels what a 18 T would do for a G5 with its 19" wheels.
CMW should have the sprockets in stock but they may not be listed on the stores website.
Logged
FiRE Comms
Bulleteer
'11 C5
Reply #12 on:
October 10, 2011, 04:14:29 pm
Ice, thanks for clearing that up for me...
Logged
Chris
TWinOKC
Grand Gearhead
Reply #13 on:
October 10, 2011, 07:48:22 pm
Considering the available power to these bikes. The 5 speed is just right. The older bikes have a 4 speed that worked pretty good for a long time. IMHO the C5 is set up just as it should be. I would not want to change anything (including the counter shaft sprocket). Maybe I am just a little lazy, the 6 speed would be too much shifting for me.
Logged
2010 C5 Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
Grand Gearhead
2010 Teal C5
Reply #14 on:
October 10, 2011, 09:09:57 pm
+1. I get lost a lot when I have a 6 speed gearbox. What gear was I in again?
Logged
Print
Pages: [
1
2
3
All
Go Up
« previous
next »
Call Me Crazy...
Login
Welcome,
Guest
. Please
login
or
register
Have you missed your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
