Author Topic: C5 front wheel hop  (Read 1470 times)
eggman65
  • REV THAT THING!
on: September 24, 2011, 11:11:31 pm
While riding my 2010 C5, I can feel what seems to be a front wheel hop.
The bike has only 270 miles and tire pressures set to owner's manual specs.
I feel this hopping when riding between 30 and 40 mph.
Thoughts?
Wheel balance?
Steering head bearing?
2011 Ural Tourist (sidecar rig)
2010 Royal Enfield C5 Classic
2007 Kawasaki Ninja 250R
2003 Harley Davidson 883R
2002 Yamaha Vstar Classic
1985 Honda CMX250 Rebel
1984 Honda ATC 200s
1983 Kawasaki KZ440 LTD
1980 Honda CX500 Custom
1973 Honda CB450 k6 (café racer)
Desi Bike
Reply #1 on: September 25, 2011, 12:02:49 am
My first guess would be wheel balance. How does the hop come on, suddenly or does it build up in intensity? You say that it has 200 or so miles, has it been doing this since new, or is it a new occurence? If possible, you might get your dealer or yourself to rotate the rubber tire on the rim and see if that changes anything. Its a low tech way to change the ballance a bit, but not a final solution. The final solution would be to get the tire rim combo balanced properly, should be covered under warranty.
میں نہیں چاہتا کہ ایک اچار
Vince
Reply #2 on: September 25, 2011, 12:13:51 am
     An out of balance wheel hops progressively worse as speed builds. If it smooths out after 40 MPH it probably isn't a balance issue. 30 to 40 MPH is the classic speed indicating a steering bearing issue. The steering head bearings will probably need to be snugged down.
Maturin
  • My Precious
Reply #3 on: September 25, 2011, 09:58:11 am
Another possibility is that the front rim - or tire -  is out of round, although this should be more obvious at lower speeds. But it´s easy to check, you only have to put some weight on the rear until the front comes up and rotates freely. If the brake pads don´t touch the disc, you´ll even recognize an unbalanced wheel, although I´m with Vince here: steering bearing is most probable.
2010 G5
Walter Röhrl
eggman65
  • REV THAT THING!
Reply #4 on: September 25, 2011, 05:46:22 pm
Thanks all. I'll pay closer attention to the "hop" and see how it changes at higher speeds.
I have a bike lift and will us it to get the front wheel off the ground and make some checks. If the steering head bearing needs tightening, that would be the big nut just below the speedo, right? Is there are torque spec?
1984 Honda ATC 200s
Reply #5 on: September 25, 2011, 11:26:17 pm
 Not counting the rims I bent, the most frequent cause of wheel hop or wiggle in my Bikes with spoked wheels has been the tires beads not seated concentrically on the rims.  Deflating, re seating and re inflating fixes it.
