Author Topic: empty silencer  (Read 2013 times)
gillonnet
on: September 14, 2011, 02:18:44 pm
hi, do empty silencer(just pipe) effect  UCE EFI Engine performance?
thanks ???
prof_stack
Reply #1 on: September 14, 2011, 02:36:02 pm
Yes it will.  Less low end power, more high-end (as it were) power, and a louder report that will get everyone's attention (usually not in a good way).
Removing the cat will also put more crap into the air.
On its own, the EFI computer cannot handle the change properly.
GlennF
Reply #2 on: September 15, 2011, 12:39:32 pm
... and lets not forget fuel consumption of a ferguson tractor.
Fitting 1 3/4 " Harley drag pipe torque cones in the headers will offset some of the negative effects by blocking pulses bouncing back up the open pipes - but you still have the problem of no back pressure.  Open pipes are mainly for looks and generally are used for show bikes and bobbers only.
« Last Edit: September 16, 2011, 03:43:58 am by GlennF »
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Reply #3 on: September 17, 2011, 05:16:22 am
This is my experience too.. way too loud. This bike needs some dampening and back pressure to run well. The EFI pipe is a good choice.
BRADEY
Reply #4 on: September 17, 2011, 02:33:42 pm
They are bad for your bike...... :(
