Per Chumma's instructions, swapped the P6 needle jet and 200 main for a P4/185 combo. Air screw is now about 3/4 of a turn out from bottomed, which worked for an initial start-up and stationary check, but I need to do some riding to get it hot and re-adjust.
Floats a little when dropping back to idle after some mild revs, around the 1200-1300 RPM zone.
