I'll fix it one of these days.
I love the stainless oil lines! Where did you source those? I think I'm going to have to do that to the Blackhawk. Looking good!
Do you get equal or sufficient oiling to your intake side with this hose arrangement?
Can't start the engine yet to say for certain, but obviously that is the anticipation.My original plan was a tee fitting to both intakes, but Chumma felt this was a simpler way to accomplish the same thing. The RE factory (to best of my knowledge) oil cooler fitted to the Fury routed this way, too.With the hopped up hi-flow oil system, I sincerely doubt we will see a lack of oil at the intake rocker, but it will be the first place I check on startup.
Need an odometer is the issue.
