My "new" RE
31 Guests, 2 Users
wildbill, Scotty Brown
May 29, 2016, 10:09:35 pm
Author Topic: Sticky ignition switch  (Read 690 times)
Desi Bike
« on: September 10, 2011, 10:51:00 pm »
My key switch is getting kinda hard to get the key in and out of. What can I lubricate it with to avoid gumming it up? Graphite? A drop of oil?
میں نہیں چاہتا کہ ایک اچار
Re: Sticky ignition switch
« Reply #1 on: September 10, 2011, 11:09:25 pm »
A real light weight machine oil that's made for sewing machines and other lightweight equipment  like 3 in 1 works well.
It's just my opinion but I would not    recommend WD40 as it tends to get gummy after a few days.
If you live in a humid area graphite will work well too but it looses its lubricating properties if the humidity gets real low.
GlennF
« Reply #2 on: September 11, 2011, 04:53:46 am »
Note ... EITHER graphite OR light oil
using both at once creates a gummy kind of glue
FiRE Comms
  • '11 C5
« Reply #3 on: September 11, 2011, 10:30:05 am »
check and make sure the ignition has not loosened up and is turning with the key.  The Large black nut loosened on my C5 making it difficult to remove the key is the ignition had twisted.
Chris
Desi Bike
« Reply #4 on: September 11, 2011, 12:12:53 pm »
switch is secure... Out comes the singer sewing machine oil I guess. Thanks everyone
« Reply #5 on: September 11, 2011, 08:07:12 pm »
Even sewing machine oil can get sticky.  This is my fave for locks, graphite in a solvent carrier.  It won't get gummy or sticky.  Stains like red mud if you get it on clothes ;)
http://www.amazon.com/Lock-Ease-Graphite-Lock-Fluid-3-4/dp/B0006MWPZA
I like the squeeze bottle but there's an aerosol too.
« Reply #6 on: September 11, 2011, 09:39:40 pm »
+1 to Lock-Ease  ;) Displaces moisture too !
 Used to dose the locks on the old Dodge every fall, nothing worse than being frozen out of your truck.
« Reply #7 on: September 11, 2011, 10:48:25 pm »
Soooo don't miss that living in a warmer climate.  One year in NY my locks froze and I had no de-icer.  I figured I'd walk the mile or so to 7-11 and get some.  They didn't have any.  I bought a bottle of rubbing alcohol, walked the mile back, took a swig, and spit it into the lock.  Ick!  It took hours to get the taste out of my mouth.  Did I mention this was a VW bug with almost no heat that I then had to drive home in?  I don't miss the cold winters.
But I degress...
