This has been a really interesting and informative discussion. I'm far enough along with my "experiments" to be convinced that the problem with my '04 Bullet Sixty-5 was too much pressure in the oil tank. Running the dipstick in the first stop position stopped it from puking oil out of the catchcan vent. Running a traditional duckbill from the crankcase and venting the timing case return thru the catchcan to the atmosphere appears to have eliminated the problem of leaking oil at the headgasket.. I now believe that my problems started when I installed the K&N pancake filter. The old airbox had a nipple that was attached to the catchcan vent. This created a slight negative pressure that kept air flowing through the oil tank. With no good place to attach the vent hose to the K&N, I left it off. The original duckbill which ventilated the crankcase into the catchcan apparently was then pressurizing the oil tank, timing case, tappet cover and valve covers, causing various small oil leaks, especially on the pushrod side of the head gasket. At some point the vent in my dipstick, must have gotten partially blocked making the problem of over-pressurization worse.
