Author Topic: What are these "tabs" for?  (Read 2539 times)
gunnerasch
on: September 03, 2011, 06:51:57 pm
Got the swing arm off, sand blasted and its ready for its first coat of primer. Getting the frame ready for sand blasting and ran into an issue. There are two "wings" welded to the main front frame downtube. They dont appear to be attached to any of the functional bits..but before I plasma them off..I thought Id ask to see if they were tank attachments or something important.
https://picasaweb.google.com/104042282269066802602/RoyalEnfieldRestoration#5648191112843402994
Thanks!  If they are not important..Ill wack em off with the plasma cutter, and grind the frame smooth where they were.
Gunner
Reply #1 on: September 03, 2011, 10:51:07 pm
It looks like someone stuck them on as an afterthought. They certainly don't look original. Probably had a different tank mounted to it.
ERC
Reply #2 on: September 04, 2011, 12:35:00 am
They definitely aren't original.   ERC
gunnerasch
Reply #3 on: September 04, 2011, 02:05:18 am
Ok, thanks!  Off they come!!
Much obliged.
Gunner
Desi Bike
Reply #4 on: September 11, 2011, 04:47:46 pm
i know you've torched it off already, but it might have been a side car mount? Butcher job?
میں نہیں چاہتا کہ ایک اچار
Blltrdr
  • cycle-delic music
Reply #5 on: September 11, 2011, 10:39:12 pm
I would suspect coil mounts.
2003 Classic 500 5 spd
2009 HD FLHT Police 103 6 spd
GlennF
Reply #6 on: September 12, 2011, 05:09:06 am
nah .. that doesn't explain why they are both sides of the frame ... unless they fitted matching left and right sidecars  :-\
My vote is mounts for home made engine bars.
Reply #7 on: September 12, 2011, 05:29:12 am
Based on the quality of the welds I'm guessing it was a High School metal shop project where everyone got to have a stab at it.  :D ;D
