vince's motorbike
May 24, 2016, 01:03:41 am
Author Topic: What did you do on your non Royal Enfield motorcycle today?  (Read 54697 times)
Rich Mintz
  • Daily rider in the city
Re: What did you do on your non Royal Enfield motorcycle today?
« Reply #630 on: July 07, 2014, 07:57:23 am »
My RE is in the shop, but over the weekend I resurrected my 2010 SYM Symba 100cc (a Honda Cub clone, with largely interchangeable parts, made in a factory in Taiwan that used to make Cubs for Honda). It needed a new final drive hub and bearing. Here you can see the old and new parts:
https://www.dropbox.com/s/0n3ox7g9xl3rs6c/2014-07-04%2013.48.36.jpg
And on Saturday I rode the bike up to Palisades, NY for the periodic "Bikes and Breakfast" gathering at the Market on highway 9W. Mine is the red and white clown motorbike in the foreground of this photo:
https://www.dropbox.com/s/i18qdeofm0re7vd/2014-07-05%2011.00.33.jpg
It won't win any speed demon awards, but it can hold to 52 mph on the flats even with my fat backside on it, and it's 100% highway legal in New York and New Jersey...
Rich Mintz - New York City
richmintz@richmintz.com
[/URL]
« Reply #631 on: July 07, 2014, 08:04:17 am »
Wow!  That hub sure is banged to hell for only being 4 years old!  When I first started reading I was thinking "why is he changing the hub already?"  And then I looked at the pic.   :o
Scottie J
Rich Mintz
« Reply #632 on: July 07, 2014, 09:08:37 am »
Scottie, I've had a lot of trouble with that hub. The driven sprocket is attached by 4 bolts that run through those channels, and it's separated about half a dozen times in normal use, no matter how much loctite I use and how tightly I attach the lock washers.
Since I seem to be the only one with this problem (the Symba community isn't as active as the RE community, but it's fairly active), I ordered a replacement hub, and sure enough, the channels run straight through. I'm guessing that I ended up in a progressive wear scenario, where running with loosened/wobbly sprocket bolts put extra stress on the channel mouths, which in turn created the opportunity for more bolt wobbling.
(It's also worth noting that I flog this bike, just like I flog my RE. I'm a large person and I ride it hard, on crappy city streets... all according to the philosophy that I bought these vehicles to use, not to keep locked up.)
So far I've done a hundred miles on the new assembly and there's no indication of anything loosening...
[/URL]
olhogrider
  • Black C5
  • 2012 C5
« Reply #633 on: July 07, 2014, 12:19:41 pm »
Sounds like it was just a fluke. I had a SYM Wolf 150 for a while. It was a little gem! I sold it to my daughter's best friend to learn on. The only thing I didn't like was the giant SYM on the gas tank. Powder coat and a set of custom decals took care of that.
bob bezin
  • I ride therefore I am.
« Reply #634 on: July 11, 2014, 01:55:52 pm »
today my son and i picked up a free kawasaki on off road bike about a 250 cc .the back brake was locked up .the bike had'nt run i n 2 years . the tank is rusty. the spark plug wire connector was broken off . in other words ruff shape . we got it running in about 1/2 hr. now to clean the gas tank , fix the brakes etc. what fun. it even has a title.
2015 indian chief vintage
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
Sam Simons
« Reply #635 on: July 18, 2014, 05:30:22 pm »
Took a few pics of the finished TW200....
azcatfan
  • 2002 Bullet ES
« Reply #636 on: July 25, 2014, 09:41:51 pm »
Lots of cool bikes in here  8)
As for me, I got the wife's Night Hawk out of storage and made it roadworthy again:  Cleaned the carb, and a new front tire and tube.  She seemed pretty happy, and now I'll have a riding buddy on the weekends  ;D
« Last Edit: July 26, 2014, 09:07:40 am by azcatfan »
bob bezin
« Reply #637 on: July 26, 2014, 07:52:12 am »
i hope you can keep up with her.
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
azcatfan
  • 2002 Bullet ES
« Reply #638 on: July 26, 2014, 09:10:35 am »
That little CB250 does pretty well for itself.  With half the displacement its about on par with the RE when I rode it as far as acceleration goes.  I'd guess it is 80 to 100 pounds lighter, and does have a higher top end than the RE going up to 65mph comfortably.
bob bezin
« Reply #639 on: July 26, 2014, 02:28:07 pm »
i just swapped my wifes little wildfire bike. it's supposed to be like a mustang scooter. but it was too small for me (seat spring wise) because she never did get her licence certified for cycle . i got a suzuki gn400 single.rode it home about 40 miles. runs real good. but pops when i let off on the throttle. when i had that problem on my norton i adjusted the air screw. this bikes carb dos'nt seem to have one. any ideas?
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
« Reply #640 on: July 26, 2014, 03:23:01 pm »
sucking air on a leaky rubber intake?
point rubbing block worn, closed gap?
hey, I've seen pics of those things bobed,BoB, great looking rat bike.
          - Mike
gizzo
  • Live slow, die whenever
« Reply #641 on: July 27, 2014, 05:44:33 am »
Have a look on the carb body for a brass plug. Chances are that if you lever it out with a screwdriver, you'll find an air screw in there you can adjust to fix the popping. That's the case on my Suzuki savage 650 single. They do the same popping thing.
simon from south Australia
Continental GT
Suzuki Savage bobber
Pantah
Monster
DR250
bob bezin
« Reply #642 on: July 28, 2014, 02:41:49 pm »
thanks guys i'm gonna run right out there and check it out.
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
bob bezin
« Reply #643 on: July 28, 2014, 06:57:47 pm »
geez no results i guess i'll live with the popping.
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
bob bezin
« Reply #644 on: July 30, 2014, 07:55:19 am »
returned the gn400. it was'n that great.
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
