1999 Enfield Bullet 350 Standard
February 09, 2016, 08:53:51 pm
Author Topic: False Neutrals  (Read 2597 times)
olhogrider
  • Black C5
  • 2012 C5
Re: False Neutrals
« Reply #30 on: September 06, 2011, 01:00:54 pm »
I was thinking viscosity of the oil as the cooler air would result in thicker oil. Today is a bit warmer. Got to go ride and check it out.
As for footwear, it hasn't changed. My shifting technique hasn't changed in 40 years of riding. That is, except for those automatic scooters I have owned. They never missed a shift. ;D
Could have been the switch from Repsol to Castrol. We'll see.
prof_stack
Re: False Neutrals
« Reply #31 on: September 06, 2011, 01:10:22 pm »
Only when my C5 is hot does shifting become less precise, and that is usually when I forget to downshift to neutral before coming to a stop.
I keep looking for that magical neutral finder, but it disappeared!   ;D
Re: False Neutrals
« Reply #32 on: September 06, 2011, 03:33:57 pm »
Mine works very well, thank you. I miss a shift occasionally because my foot doesn't come up far enough, but then so would any other bike I've ridden. When I first got it I missed a lot of 3rd to 4th shifts, but either my technique has improved or the gearbox broke in. I suspect it was just my learning what the bike expected.
olhogrider
  • Black C5
  • 2012 C5
Re: False Neutrals
« Reply #33 on: September 06, 2011, 04:35:01 pm »
I suspect its British heritage was repulsed by the Spanish oil. Just did 50 miles of twisty 2-lane. Only two missed shifts. That is acceptable and a huge improvement. Probably something in that Castrol that it likes. Whether it is the clutch or gears, I don't know, but it is much happier now.
BrashRooster
  • Yeah I stepped in it.
Re: False Neutrals
« Reply #34 on: September 08, 2011, 11:38:32 pm »
I have a B5 and on my post titled been along time I didn't complain on "false nuturals" not because I don't get them I do but I know that they have been my fault. My 250 rebel I traded in with 20,000 miles (purchased new in 2006) had a tendacy for the rider to miss gears when shifting and my 1982 yamaha xj650 maxim and my 1974 honda cb550. I know it is me not the bikes but I actualy think the B5 is more forgiving. My xj650 would pop into nutural if I pulled to hard in first because I had a bad habit of getting on it and not shifting soon enough. I do have lots of experience at replacing a clutch. The little rebel was on its third one in the 20,000 miles I rode it. So far 1500 miles on my new B5 in less then a month since I owned it I honostly can't complain about the motor or clutch. Now I would recomend the B5 despite my uh issues I had. I can not make a connection between my starter and my exhaust pipe breaking. I have to believe it was coincedence or karma. Yes I was pretty upset but it would not be fair of me to say the B5 was troubled. I think my dealer was very good to me and has done a wonderful job helping me. I think if you got a B5 you would probably be like me and wonder why theu didn't make the uce engine a little sooner.
Signature
Re: False Neutrals
« Reply #35 on: September 09, 2011, 04:58:26 pm »
Is it hard to find neutral when you're  stopped? If it is, your clutch is probably dragging a bit. Check your cable play.
Desi Bike
Re: False Neutrals
« Reply #36 on: September 09, 2011, 05:59:57 pm »
If i dont get it to noootral before coming to a stop, my trick is to drag the clutch just barely to preload the transmission. I'm able then to clunk it around to newt-ral with ease. Elsewhere on the threads somewhere on the internets I read that holding the clutch in is bad news for the clutch, so I am always dropping my bike into new-trawl at any stop longer than a few seconds, and it gives me so time to stretch and gaze around at the surroundings, surf the web, make meaningless replys such as this on the forum while at a red light....  :p
میں نہیں چاہتا کہ ایک اچار
aikischmid
Re: False Neutrals
« Reply #37 on: September 10, 2011, 12:09:56 pm »
I was pretty concerned about all the false neutrals I was getting the first couple weeks I had my G5. But someone said it just takes some time getting used to, building a relationship and learning about the bike - weird mystic mojo type stuff that I of course thought was nonsense. But guess what? I haven't had a single false neutral at all in the past couple weeks (I've only had the bike like a month), and I attribute that to just riding it, and learning it, and building a relationship with it. So weird I know, but it's the way it's been for me!
2011 Royal Enfield G5 Classic, British Racing Green
Re: False Neutrals
« Reply #38 on: September 10, 2011, 12:56:57 pm »
I think that's the way it works for about all the Bullet owners. Once you get it figured out, then it's yours and you're stuck with it.  :-*
The bad news for the clutch when you stopped and not in neiut-ral is that the  pushrod from the actuator is dragging and doesn't have a throwout bearing to ride on, so the end is wearing down. And your clutch bearing is spinning and will wear out sooner. If it's in gear and rolling or in nootral and stopped the bearing isn't being used. On the same thing though, if you are having trouble finding newtral when you are stopped the clutch probably isn't releasing completely. Usually proper adjustment will fix that, but it could be a warped disk or uneven springs, or even a dragging clutch bearing.
bman734
  • If it smells nasty, don't eat it
Re: False Neutrals
« Reply #39 on: September 11, 2011, 06:58:40 am »
I've never had a bike that didn't have some play when trying to find neutral. My C5 at first confused me because I'd have to play around a bit to find neutral coming to a stop until I remembered that fact about my other rides. Now it doesn't bother me at all.
Royal Enfield C5 Military
Suzuki SP370
Honda CX650
Yamaha XS650
