MY 500
28 Guests, 2 Users
kodai, Farmer_John
February 05, 2016, 09:29:18 pm
Author Topic: side to side wheel base?  (Read 1196 times)
500KsGerry
  • Remember when decency wasn't a option?
« on: August 20, 2011, 03:23:50 am »
What is the distance of the sidecar tire from the center of the bike on the cozy/RE set up? Just curious, Haven't gotten to the chassis /frame build yet. Appreciate the info so thanks ahead of time . Gerry
Modified 2001 Royal Enfield bullet 500
The Garbone
  • Shade Tree
  • User Complaints: 22
Re: side to side wheel base?
« Reply #1 on: August 20, 2011, 01:18:57 pm »
Check here ====> LINKY
I will go out and measure mine, but I know the slip joint do allow an inch or two of adjustment on the width..
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
500KsGerry
« Reply #2 on: August 20, 2011, 01:48:07 pm »
Excellent linky there Garbone . Thank  you! Some  good  info .
Since this one will be a 2/3 leaner to start with I will be going for the zero-scrub. Was good  to confirm  that on  your link.  Combined with the chair being narrow/kinda short, with the seat center between the leading edge of the rear  rims and the swing arm pivot points will  provide about 1 square foot of optimal area for load (butt). Does make for a small area for CG  so very minimal cargo will be able to stow in the nose. It's mainly a puppy/grand kid chair anyhow.
 pic added of basic design though not to scale
« Last Edit: August 21, 2011, 10:57:42 pm by 500KsGerry »
GA-DK
« Reply #3 on: August 20, 2011, 07:00:03 pm »
Mine measures 46.5" from and to center if tires.  It could be set up about 1" less or a few inches more.  My Cozy Euro is fitted with mounts of my own design.  I would never use the monstrosities that CMW sells as a G5 adapter.  It would totally block the kickstarter and would be very weak and bound to crack in a short time.  All in all a very poor design.  GA-DK
500KsGerry
« Reply #4 on: August 21, 2011, 03:09:59 am »
Mine measures 46.5" from and to center if tires.  It could be set up about 1" less or a few inches more.    GA-DK
This  is  great.  Was thinking 42 inches max  for  mine...skinny  car.  Can't wait till I get to fiddle with the geometry  of the actual parts some more to see how narrow I  can get it all with the needed  clearances. Thanks GA-DK
500KsGerry
« Reply #5 on: October 01, 2011, 05:15:31 pm »
Ended up at 44 inches on  build. Thanks for the info  guys. Gerry
