rear look
July 31, 2015, 11:06:10 pm
Author Topic: New Pictures - Picture Tips  (Read 6824 times)
  • Administrator
« on: July 23, 2007, 12:16:11 pm »
We have uploaded quite a few new pictures to the Photo Gallery. You may find them interesting. When you upload your own photos, if you want them to be available to Google and other search engines and be seen widely on the Internet there are a couple of things you can do when  adding pictures.
1. Name the file in a descriptive way. For example "royal enfield motorcycle with engine performance modifications" Be direct and don't get carried away.
2. You will also notice a spot to add keywords. These can be important. Use words like "royal enfield motorcycle, vintage british motorcycle, classic cycle or other words that people may use as search terms. Again don't get carried away by adding things like sex or Harley Davidson which while often times searched are not accurate for most pictures likely to be posted on this site.
Note: You do not have to do any of this to successfully upload pictures. It only helps search engines find your pictures
« Last Edit: July 23, 2007, 03:56:47 pm by Royal Enfield 1 »
