2014 Continental GT 535
May 27, 2016, 03:09:50 pm
Author Topic: Horn Bracket. Do-it-yourself Instructions.  (Read 1477 times)
Byway
  • Inner State.
« on: March 15, 2008, 02:29:20 pm »
I didn't care for the stock position of the horn on my '01 Bullet so I decided to make a simple bracket to place the horn into a more "period correct" orientation. It will suffice until I get around to buying a pretty Altette horn and bracket!
Dimensions:  3 1/2" long x 1" wide x 1/8" thick.
Purchase a  1" wide by 1/8" thick steel bar (I found one at Home Depot).  Buy a 12" one if you can find one since you'll only need about 3 1/2" of it.
Cut off a 3 1/2" piece with a hacksaw.  Drill one 5/16" hole about 1/2" from one end, and one 3/8" hole about 3/8" from the other.  Enlarge the 3/8" hole slightly with a rat-tail file to fit the horn.
Round the ends of the bracket with a flat file, if you like.  I rounded the end that mounts to engine mount (for appearance purposes) but chose not to bother with the horn end.
Paint, install (see important not below), and enjoy!
Note:  Make certain not to disturb the position of the horn's adjusting screw on the back side of the horn!  Make a note of it's position and, if it moves, make certain to re-adjust it when you're done of your horn will either sound weird or not work at all!  I had to tweak mine a little after I had it mounted on the bike but it was fairly easy to do.  If it's not set right, you'll know it!
This is a pic of the bracket:
This is a pic of the "rear" side of the bracket and horn after installation (note that the horn is mounted to the bracket with a nut on the actual adjusting screw!:
This is a close-up of the "front" side of the installed bracket:
This is a pic of the horn.  Same location but with old-school orientation!  If only the stock horn wasn't so "homely" looking!  :P :
Let me know what you think about this mod. or if you have any questions!
Al
« Last Edit: March 17, 2008, 12:49:10 am by Byway »
2001 Royal Enfield Bullet Classic;  1988 Yamaha Virago 535;  1999 Suzuki Katana 600; 2001 Honda CN250 Helix;  1972 Honda CB350SS.
Byway
  • Inner State.
« Reply #1 on: March 15, 2008, 02:51:02 pm »
ETA combined to above post.
« Last Edit: March 17, 2008, 12:53:35 am by Byway »
