Me n me Lady
February 11, 2016, 03:39:11 pm
Author Topic: R.P.M @ 60 (55)  (Read 3715 times)
R.P.M @ 60 (55)
« on: March 10, 2008, 02:12:26 pm »
Has anyone tached out their classic at 60 mph (indicated) ? Looking for a ballpark figure, stock (17t) sprocket. Thanks.
fredgold52
  • Macomb, IL Flatlands Rule
Re: R.P.M @ 60 (55)
« Reply #1 on: March 11, 2008, 03:08:46 pm »
I wanted to bump this back up - I'm interested in knowing what RPM's we are turning at various speeds too.  I know this is sort of a lazy engine and that's one of the reasons I like it so well.  But still, RPM's would be nice to know.
Re: R.P.M @ 60 (55)
« Reply #2 on: March 11, 2008, 03:28:35 pm »
I cant believe no ones done it yet! I guess I'll have to dig up an old dwell meter or the like. Haven't seen any of those old tuneup tools in 20 years. I'm going to take a guess at 3800 and hope I'm wrong.
Foggy_Auggie
Re: R.P.M @ 60 (55)
« Reply #3 on: March 11, 2008, 07:37:41 pm »
Transmission ratio in 5th gear.
Sprocket ratio = rear sprocket / front sprocket
Engine rotation / km = trans ratio * sprocket ratio * wheel rotation / km
Engine rpm = engine rotation / km * bike speed / 60
One mile = 1.609 km
Wheel rotation travel found by using a string to measure the distance traveled in one rear tire rotation.  Can be performed on the center stand with a helper.  Measure in inches - convert to millimeters - convert to three decimal points of meters.
(example only:  wheel travels 65.25 inches in one rotation - this equals 1658 mm = 1.658 meters).
Fortiter Et Fideliter
Re: R.P.M @ 60 (55)
« Reply #4 on: March 11, 2008, 08:36:17 pm »
                                       FOUND IT!
Below is a post from "DWM" Dave was the builder of Hanuman in the members
rides. What he didn't know he figured out and shared.   - Mike
I wanted to know my RPMs at different speeds, so got this little tach;
http://www.tinytach.com/tinytach/gasoline.php
Not bad for $37 US, being digital, it's useless for shifting. but, if you need
a
tach to shift a
RE, you're stone deaf, and yer butt has gone to sleep. Also has a 2 second lag.
Anyway, here are speeds/RPMs, with a 19T countershaft sprocket on the five
speed.
(XT- extrapolated.interpolated)
50MPH-2870 RPM
55MPH XT - 3146 RPM
60 MPH - 3450 RPM
65 MPH XT- -3737 RPM
70 MPH - 4025 RPM
75MPH XT - 4312 RPM
80MPH - 4600 RPM
85MPH XT- 4887 RPM
Theoretical;
90 MPH XT - 5175 RPM
MAX RPM-5500 - 95MPH
The speeds above are from a GPS corrected speedo, and I think they're pretty
tight
numbers.
I don't think the bike would do 95 MPH if you pushed it off the Sinny Arbor
Bridge, but it
touches 85 with my 220 lb on board, so I think a lighter rider would see 90.
(535cc, 8.5:1. 34mm Mikuni, short Brit exhaust, K&N)
More importantly, it means my "75 MPH all day, 80 to pass only," are usable
limits. I just
can't see that motor objecting to 4300 RPM. It sure sounds relaxed.
Below are extrapolated numbers for 19 and 18 tooth sprockets;
18T (19/18ths of above RPM)
50MPH-3029 RPM
60MPH-3642 RPM
70MPH-4249 RPM
80MPH-4855 RPM
17T (stock, 19/17ths of 19T readings)
50MPH-3207 RPM
60MPH-3855 RPM
70MPH-4498 RPM
80MPH-5141 RPM
BTW, I installed the black bar-end mirrors from CMW on "Lady Triumphantes", the
$15
ones, and they have been fine. Of course, the Trumpet vibrates a bit less.
Best,
DWM
jdrouin
Re: R.P.M @ 60 (55)
« Reply #5 on: March 11, 2008, 08:50:01 pm »
Wow! Cyrusb's guess of 3800 rpm on a 17T countershaft sprocket is pretty much dead on, balls accurate.
Jeff
« Last Edit: March 11, 2008, 08:51:32 pm by jdrouin »
Re: R.P.M @ 60 (55)
« Reply #6 on: March 12, 2008, 11:52:36 am »
Thanks baird444, I printed that out. I had a feeling the revs were in the high 3000's but didn't think my guess was that close!
Bankerdanny
Re: R.P.M @ 60 (55)
« Reply #7 on: March 12, 2008, 01:53:07 pm »
dead on, balls accurate?
Endeavor To Persevere
luoma
Re: R.P.M @ 60 (55)
« Reply #8 on: March 12, 2008, 06:10:04 pm »
Appreciate the info. My bike has a 19-tooth also. It feels pretty tight at 75, but I guess it's not.
jdrouin
Re: R.P.M @ 60 (55)
« Reply #9 on: March 12, 2008, 06:43:40 pm »
That's Marisa Tomei's line in My Cousin Vinny. She's the daughter of a mechanic who clinches the mystery of an armed robbery at the end of a lost-cause trial.
http://www.youtube.com/watch?v=DhL5exi_avE
Jeff
Re: R.P.M @ 60 (55)
« Reply #10 on: March 12, 2008, 07:33:03 pm »
I have never seen that film Jeff but I liked the clip!!!!  ;D
jdrouin
Re: R.P.M @ 60 (55)
« Reply #11 on: March 12, 2008, 09:10:36 pm »
Actually, I sent the wrong one. It's in this clip, from about 1:15 to 2:15. For some reason I thought the line was repeated later as a clincher in the trial, but it wasn't. The technical humor is good in this one too, as well as certain other... ahem... aspects.
http://www.youtube.com/watch?v=M-ZyxRNCTuc
Jeff
Re: R.P.M @ 60 (55)
« Reply #12 on: March 14, 2008, 04:47:45 pm »
The  new clip is "Dead on, balls accurate" !!!!  ;D
Re: R.P.M @ 60 (55)
« Reply #13 on: March 14, 2008, 05:05:12 pm »
Its an industry term!
Re: R.P.M @ 60 (55)
« Reply #14 on: March 15, 2008, 11:46:26 am »
Maybe I'd better not ask which 'industry' if it turns out to be the worlds oldest profession  ???  :o
