Author Topic: Daughter Laid Her C5 Down / Not Hurt / Shifter Disconnected  (Read 4016 times)
ChristopherRyan
  • Christopher Ryan
Adrienne and I are on our Route 66 trip. Perth, Ontario, to LA.
She laid her bike down in Miami, Oklahoma. The shifter shaft moves in and out by one inch and is not connected to any internals. Can shift down. If I remove the (bent) foot peg, I can rotate the shifter 175 degrees and shift up.
What should I tell the repair guy and what is he likely to tell me?
Reply #1 on: August 18, 2011, 04:46:47 pm
Sorry to hear about your mishap, but certainly glad to hear she's OK.
There is a dealer in Tulsa. I don't know if there are any others in that area
The mechanic will have to pull the right hand cover. Hopefully the damage will be limited to the arm that  drives the shaft that that goes into the gearbox. It may have come loose so that it will spin on the shifter shaft accounting for the fact that if you turn the shifter around it will catch again. Or, most probably, it may have just popped out of the fork. No way to tell without pulling the cover. It would seem to be the most vulnerable thing that would let the shift shaft move in and out. If it goes deeper than that, it's an engine teardown.
As far as what to tell him, what you said here is probably the best thing.
« Last Edit: August 18, 2011, 04:58:34 pm by barenekd »
Reply #2 on: August 18, 2011, 05:00:39 pm
Glad the girl is in good shape, good luck!
Vince
Reply #3 on: August 18, 2011, 05:07:42 pm
     The shift shaft goes all the way through to the other side of the engine. It has a tab  that fits into a notch on the vertical shaft that moves the shift plate. It sounds like one side of the notch is broken off. The entire right side of the engine will have to be disassembled to get to it. You need to repair it now because if that notched piece is broken off you have a chunk of metal floating around in the crank case. It will wreak havoc if it gets between a couple of gears.
     The shift shaft is located with circlips that may have popped off, causing the side to side movement These will be under the left engine cover. Because of this, the shifting issue may just be that the tab popped out of the notch and nothing is broken. However, the right covers still need to come off to inspect and re-locate the mechanism.
      Wish I had better news.
     Glad your daughter is OK.
Reply #4 on: August 18, 2011, 06:10:58 pm
Glad to hear you daughter and riding buddy is o.k.
TWinOKC
Reply #5 on: August 18, 2011, 07:17:59 pm
Glad you and your daughter are okay, the bike can be fixed.
And Welcome to Oklahoma!!   Where the wind comes sweeping down the plains!
Terry
2010  C5  Teal
2011 Triumph Bonneville T100
2015 Scrambler Ducati
Reply #6 on: August 18, 2011, 07:39:57 pm
Wish you and your daughter a safe ride ahead. Glad that she is OK.
The picture below shows the notch that Vince is talking about - on the right side of crankcase.
Reply #7 on: August 19, 2011, 12:58:28 am
Thank you for the pic Br. Singhg  :D
 On taking a closer look at it the shift shaft may have some other possibilities,,,,,like a R/H shift conversion  ;D
Chiefharlock
Reply #8 on: August 19, 2011, 03:34:24 am
Chris, PM me and let me know when you are running back through Missouri.  I'm stationed right off the route and would be happy to provide you any assistance you need if you are in need be it a place to rest from the road for a little while or a meal and friendly conversation  of any and would love to talk with you both about your travels as I am currently planning a Route 66 trip for my best friend and I and would love to ge your input on things!.  Plus there is a RE dealer about 20 min from my location.
Glad to hear that your daughter is OK!
~JP
Ton Up!
ChristopherRyan
  • Christopher Ryan
Reply #9 on: August 19, 2011, 04:27:42 am
Hey Guys,
You saved me big time.
The finger was bent and popped out of the notch.
This morning, I considered shipping the bike back to Ontario and flying my daughter. Alternatively, I was going to leave the bike in Miami for ten days. Instead of canceling the trip on day five, we will be on the road tomorrow.
We are going to slow down though. We were trying to make it to a camp ground and she out ran her headlights.
The C5 is a tough bike and so easy to repair.
The guys at Route 66 Custom Cycles are wonderful.
Reply #10 on: August 19, 2011, 04:38:43 am
That is very good news and I'm glad to hear it.
Have you considered a 7" headlight kit ?
Not to ride faster but to increase detection distance and afford more reaction time.
An H4 bulb takes up little room in the spares kit too
BTW did your daughter get checked out at the doctors ?
Some of us sustained injuries that turned out to be worse than they looked.
« Last Edit: August 19, 2011, 04:50:04 am by Ice »
Raj V
Reply #11 on: August 19, 2011, 02:57:57 pm
Hi Christopher,
I have driven through Perth, ON, many times and always liked the place. I hope everyone is doing well and you get to complete the journey.
Raj.
Reply #12 on: August 19, 2011, 05:05:39 pm
Glad to hear you're on the road again. When you get to CA, PM me.
Reply #13 on: August 19, 2011, 06:28:57 pm
Three cheers for Route 66 Custom Cycles!  I took a look at their site and the owners both seem to have extensive experience with many things mechanical.  I'm also glad to hear the UCE living up to the reputation of the old Bullets: easy to fix no matter where you are!
Every worhtwhile adventure requires a little adversity.  I'm glad you're on the road again and that you've chosen to slow down.  The number of miles you cover together is less important than the time you spend together.  Take it slow ;)
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Reply #14 on: August 19, 2011, 09:26:47 pm
Chris, how did you fix it? Just bend it back? replace c clip? Take both sides apart?
