Gents,
I'd be grateful for some guidance with a couple of problems. First, my speedometer shoots up to 80-85 any time I go above 40 or so. I already searched old posts and am going to take a whack at tightening it up, but any ideas if that doesn't do the trick?
While I'm in there I'm need to figure out what's going on with my left front turn signal. It stays on, not blinking, just a solid light. All others work fine. I looked around in there and found the connection for the left blinker. It's intact. When I pulled it apart the light went out. I also found what I think is the ground (I know next to nothing about electrics. The other side of nothing). Anyway, a loose black wire with a thin flat male end looking thing. Did I say I don't know anything about electrics? Does that attach somewhere? I've got the diagram from the owner's manual and what I was told was a shop diagram, but not having any experience, I'm having some trouble making heads or tails of it. I got some of that dielectrode grease or whatever yall mentioned on some other posts. So, I'll clean up some connections and hope for the best, but I thought I may as well get the jump on asking some people who know what they are doing.
Thanks!
