I installed the NEW K&N air filter from nField gear. It is flared out so the base diameter is wider than the brackets in the airbox. So the fit is snug.
BUT, the wider base makes it so that the airbox cover (the plastic thing that now is standard on C5's (dunno about G5 or B5 versions) cannot neatly fit over the filter AND seal the base. The filter touches the bottom of the airbox.
I'm going to ride it after dinner and report back here, but perhaps I will wiggle and jiggle and use my "Enfield fitment" vocabulary to make the cover fit.
I wonder if the airbox lock will sometime soon go airborne as has happened to others. That would be fun, ... , not.
The four filters in the photo below are: OEM, early K&N prototype (too narrow a base), nField K&N, and the cone filter Scotty sent me in case I wanted to build or weld a flange onto the intake opening. If anybody wants the cone, let me know and I'll send it to you for the same price Scotty charged me. Rhymes with hero.
