Since I have an old feeble squatty body that won't bring the leg up high enough to get it on the kickstarter when I stand beside it, I put the G5 on the center stand, and get on it. First, I turn the key on, and while the pump is doing it's thing, make sure all the other switches are in the running position, side stand up, kill switch on, (like I've never forgotten to do that). Stand astride it, shove the kick starter down until it hits the hard spot, the kick it. Usually one, sometimes two kick will do it. However, if it's cool, after the first pop, I will give it a little short of throttle as it will quit after four putts. Then I have to shut off the switch and and reprime it to try again.
I use the electric starter on the occasion it quits in traffic or I'm just too lazy too put it on the center stand.
It's great to have a choice.
