You won't see any obvious damage to the ring, the problem is, they lose their temper when they get overheated, (They're not pissed, they're just got soft), and won't stay pressed against the cylinder walls letting the oil and compression get by . You can take them off the pistons and bend them very easily, where they should be breaking when you try to bend them.
