keep walking
37 Guests, 4 Users
Ice, kennwa, Captwilly, mgm
May 27, 2016, 11:16:43 am
Author Topic: g5 project teaser  (Read 592 times)
jartist
g5 project teaser
« on: July 15, 2011, 03:09:42 pm »
I couldn't wait for the paint to dry to show off my project. It's a sub-subframe for my G5 that mounts a lycett style front saddle for the pillion complete with rear rack and saddlebag mounts. More to follow...
Re: g5 project teaser
« Reply #1 on: July 15, 2011, 03:54:54 pm »
Wow !!!  :o 8)
REA #136
jartist
« Reply #2 on: July 15, 2011, 05:29:37 pm »
Done!
« Last Edit: July 15, 2011, 05:34:00 pm by jartist »
« Reply #3 on: July 15, 2011, 05:35:02 pm »
Very clean!
FiRE Comms
  • '11 C5
« Reply #4 on: July 16, 2011, 07:15:53 am »
looks good...
Chris
Maturin
  • My Precious
« Reply #5 on: July 16, 2011, 01:50:38 pm »
Nice piece! Did you modify something or did you weld freehand?
2010 G5
Walter Röhrl
jartist
« Reply #6 on: July 16, 2011, 08:12:09 pm »
Freehand. The G5 subframe is a nice sturdy clean slate to bolt stuff to. I just hope the 4 small bolts are strong enough.
greggers
« Reply #7 on: July 18, 2011, 05:52:54 pm »
I was kind of wondering the same thing. All the Nfieldgear rear seats have a frame piece that mounts to the shock bolts in addition to the small subframe bolts. I guess at least make sure you have the highest grade M6 bolts in there you can find.
jartist
« Reply #8 on: July 18, 2011, 08:26:51 pm »
I bought that rack for the G5 but it doesn't fit the 2011 because they changed the tail light assy and the trafficators are in the way.  It would work if you relocated the trafficators but I had to make a custom subframe for the pillion anyway so I incorporated a rack into that instead.  It would be much sturdier if I also mounted into the shock bolt like the nfield gear rack does.  Yes, I definately upgraded the bolts and went one size up on the two rear bolts but we'll see how the 6mm bolts hold up- they're pretty small.
