Yep...until I find NEUTRAL....I did notice that the clutch cable seemed a bit "sloppy"...so I tightened it up a bit using that adjusting barrel on the lever.
Perhaps the previous owner did that more than you.
Here's what happens.
The clutch plates are often not perfect, and when they are released by the release mechanism, they drag against each other and cause heat to build up.
This can happen within a matter of less than a minute.
Then, the steel plates warp, and the clutch will never release cleanly again until that is rectified.
The typical recommendation is to not hold the clutch lever in for more than 5 seconds, while finding neutral. Then pull the lever in again to select first when you are about to ride off. No holding it in for any period of time.
Also, holding the clutch lever in can friction-weld the clutch release rod to the ball bearing in the release rod series, and then the whold release rod will be turning and generating heat at both ends, instead of rotating against the ball in the middle. Pretty common occurrence.
Pretty much all British clutches are like this. It isn't just Enfield.
Next time you have your primary open, take the clutch plates out and check the steel plates for flatness by laying them on a pane of plate glass. You'll probably find that they are warped.
