I just finished reading the book, "BSA TWINS & TRIPLES, The Postwar A7/A10, A50/65 and Rocket III" by Roy Bacon and noticed something I think is interesting.
As many of us have found, Royal Enfield recommends very low tire pressures on our bikes.
For instance, my UCE G5 Owners Manual says the front tire should be 18 psi front and 28 psi rear for solo riding and 20 psi front/30 psi rear for dual. It lists the G5 wet weight as 187 Kg (412 lbs) I should note that the weight of our gasoline + oil is about 35 pounds so the dry weight would be around 376 lbs.
The high tire pressures common on many modern motorcycles (and that I found on my new G5 as delivered from the factory) can cause our RE's to not only ride hard but to get skitterish to the point of causing some disgusting surprises in our shorts, at higher speeds.
In the back of the book, a number of specifications are listed for all of the BSA twins and I noticed that the tire sizes and pressures were given as well as dry weights.
The A7 (500 cc, 1946-1954) used a 3.25 X 19 front tyre and a 3.50 X 19 rear.
Recommended tyre pressure: 16-18 front, 17-20 rear (solo) and 18 front, 26-28 rear (dual). Dry weight about 382 lbs.
The A10 (650 cc, 1950-1961) used a 3.25 X 19 front and a 3.50 X 19 rear tyre.
Recommended tyre pressure: 18 psi front, 20 psi rear (solo) and 18 psi front, 28 psi rear (dual). Dry weight about 408 lbs.
The A50 and A50C (500 cc, 1962-1970) used a 3.25 X 18 (A50) or 3.25 X 19 (A50C) front and a 3.50 X 18 (A 50) or 3.50 X 19 (A50C) rear tyre.
Recommend tyre pressure: 18 psi front, 20 psi rear (solo). Dry weight 385 lbs.
It seems the tire sizes used are the same as our Royal Enfields and the weights of the bikes were very similar so it's not surprising that the recommended tire pressures for our RE's are so low.
I've heard some people say the RE's recommendations for tire pressures are so low they might be dangerous, possibly allowing the tires to slip on the rims but it seems the low pressures were common on the old bikes and I don't recall that things like that ever happened.
Maybe some of the historical information is as valuable today as it was back then. Especially when riding a bike that is the same today as they were in the 1950's.
