People need to remember, when torque values are given, the amount is for dry threads.
If the threads are lubricated or if a liquid thread lock like Loc-Tite is applied, reduce the value specified by 1/3.
This applies to the drain plug too. Usually, the threads are still wet because of the oil draining out of the oil tank so the recommended 15 ft/lb for the UCE, given in the nfieldgear catalog should be only about 10 ft/lbs. when wet.
