1960 RE Indian
February 10, 2016, 09:54:52 am
Author Topic: Re: Speedometer  (Read 2018 times)
GA-DK
Re: Speedometer
« on: July 01, 2011, 07:32:46 am »
I have wondered if it would be possible to make a small gearbox to put in series with the speedometer cable to give a 10% reduction.  A small 10-tooth Nylon gear on a short cable on bottom of speedometer driven by a 9-tooth gear on top of main cable.  A slight offset in the cable would not be seen or matter as it would be hidden.  I have also considered a 9-tooth gear inside a 10-tooth ring gear (teeth on inside of ring), but I am not sure I could make it and have it mesh properly, but that would give almost no offset in the cable.  That would probably require a non-standard gear tooth shape.    GA-DK
Re: Speedometer
« Reply #1 on: July 01, 2011, 04:23:35 pm »
My G5's improved and ACCURATE speedometer  ;D
Re: Re: Speedometer
« Reply #2 on: July 01, 2011, 06:11:13 pm »
A simple gear system with two spur gears won't work.
The rotation of the driven gear will be opposite the driving gear so the speedometer will be running backwards.
The internal ring gear system would work if the smaller internal driving gear location was fixed but with only 1 tooth difference in size I don't think it can be done.
olhogrider
  • Black C5
  • 2012 C5
Re: Speedometer
« Reply #3 on: July 03, 2011, 11:09:11 pm »
on my Vespa I simply pulled the speedo needle off its shaft and stuck it on a little lower down the scale.
bman734
  • If it smells nasty, don't eat it
Re: Speedometer
« Reply #4 on: August 13, 2011, 09:21:01 am »
So what's the deal here. As for as I can tell the speedometers are accurate. At least mine is. I tested it against my Honda Insight and 35 mph matched up with the cars digital read.
Royal Enfield C5 Military
Suzuki SP370
Honda CX650
Yamaha XS650
bman734
Re: Speedometer
« Reply #5 on: August 13, 2011, 09:24:37 am »
I love your new "accurate" speedo singhg5!
Suzuki SP370
Honda CX650
Yamaha XS650
olhogrider
  • Black C5
  • 2012 C5
Re: Speedometer
« Reply #6 on: August 13, 2011, 10:55:28 am »
I think they are calibrated for a 19" wheel. That makes us C5 riders think we are going faster. ;)
kayak65cuda
Re: Speedometer
« Reply #7 on: September 19, 2011, 07:04:25 pm »
Had never ck'd mine before. A few weekends ago I was following my wife & turns out 70mph = 65mph for the van. Good enough for me  ;D
MotorcycleMuscleCarsPowerWagonKayakingBackpaking
'08 AVL Enfield, '74 Suzuki CT185
Past rides: '99 KZ1000P, '80 Suzuki GS750
single
Re: Speedometer
« Reply #8 on: November 01, 2011, 05:54:39 am »
Yeah,I  don't care either.The thing is off,tho'.And never steady,try not to look at it much,get dizzy.Mite replace it with a tacho.
Re: Speedometer
« Reply #9 on: November 01, 2011, 01:09:40 pm »
If your speedo needle is waving around, try lubing the cable. that will usually smooth them out. get some speedo cable grease from you local auto parts store. Leave a couple of inches dry at the top of the cable, you don't want it getting into the speedo.
bare
