Righto, I got my new bike last night and it arrived with a flat battery. I charged it over night now the electrics work.
I have always confessed how new I am to motorcycles, RE in particular, so I am blaming myself here, not my equipment.
I have a hard time starting this bike. That is probably every newbie's problem. I was reading Snidal's manual and the advice on the forum. Here is what happened...
I used the decomp lever and rolled the engine a few times, then turned on the fuel, the choke, the ignition key, the kill switch to "on" and using the ammeter to tell when I was at TDC I pushed the kicker all the way through. Eventually, I got it started and it ran! Life! It exhausted blue smoke for a few seconds, which I took to be wet sumping but then it cleared. After a minute or so it started to sputter. I gave it some throttle but it died. I kicked it again and it came to life for about 10 seconds but died. That was it. No further attempts to resurrect it worked.
It was then dinner time and whilst I was eating it occurred to me that I had left the choke on! Maybe that was why it died after a minute?! So I went back and tried it again, with and without choke. No joy. No life. HMMMMM..
So I checked the points with a screwdriver. Yep, there is spark. So I unscrewed the spark plug and had a look. The gap was pretty dirty, but no corrosion. The I looked at the other end of it. I noticed bare threads. HMMmm. I have never noticed a spark plug like that. They always have a little "cap" on them.
Is that normal? Is that little cap supposed to come of and the spark plug wire fit over the top of the threaded tips? Obviously something worked because the bike did start that one time.
So, that was my first attempt at kick starting my 2004 Enfield. There is fuel, air, spark (maybe) and compression. What can I do?
The other discovery. Both tool boxes on this bike are occupied by other things. On the left side is that Pulse Air System thing, leaving not much room for any tools or other stuff. On the right side tool box is a round air filter, then it goes to a black box with a label saying "air filter wash with petrol every 2000 miles" then a tube into the carby.
So, why does that system work like that? Can I get rid of that round air filter and use the tool box? How to modify please? Would a K&N filter attached on the carby bypass all that stuff?
Thanks for reading and I could use direction on how to kick start my kick start only bike!
Regards,
Joe
