Now if only the temperature would drop below 93°, I could go ride. *sigh*
Just thought I'd update y'all on what the issue was in case someone else faces it in the future, turns out it was a faulty speedo that was shorting the turn signal (the neutral light was indeed the sensor).Took the shop guys almost 5 hours to track it to the headlight after pulling everything apart, having it work, pushing everything back together, having it not work, lather rinse repeat...
