Very nice, Singh. And the music was good, too.
If I may make a suggestion, before you tighten the axle and brake nut, crank the brake adjuster nut down where the brake is locked tight, Then tighten the nuts. This will insure the shoes are centered and and are both going to work when the brakes are applied. People who have complained about rear brakes being no good generally miss this step and only one shoe is contacting the drum
