My new fuel injected G5's idle speed is higher than I think it should be.
I'm not sure if this was intentionally done by the factory because the engine needed to go thru its break in or not but now that it has over 500 miles on it I would like to slow it down a bit.
The Service Manual says the speed should be 1050 +/- 200 RPM and the adjustment is made by turning the large slotted brass screw on top of the throttle body clockwise to slow the engine down.
At the moment I really don't know what the idle speed is but it seems to be about the same as the engine speed in 5th gear at 30 MPH. According to my calculations that is a little less than 1600 RPM. Of course this is just going by ear and that is no way to really know what the true speed is.
From my days before computers took over the control of automobiles engines I have a Tach/Dwell meter which was made to be used with the old fashioned points ignition system.
Is it possible to hook this Tach/Dwell meter to my G5's coil without toasting the computer? If not, is there some sort of dedicated connection where it could be used?
About the only other way I know of to determine the actual RPM is to use a tachometer with a inductive coil pickup and at the moment, I don't have one.
What do you guys use to set your idle speed on these EFI machines? Any suggestions at all will be appreciated.
