Thanks! The light always comes on. The EFI always runs, but the engine often won't turn over. Turning the key and starting over doesn't seem to work. I checked out the "need help testing starter switch" post and it sounds similar. That's what made me check the kick stand and clutch switches. If I charge the battery, it seems to work fine, which is what made me replace the battery. The new battery is better, needed charging this morning for my commute, but for only 5 minutes. This is rather puzzling.
I need to bring it in for a regular tune up anyway, so I need a good local mechanic that knows a little about REs. Any recommendations on that are much appreciated?
