Author Topic: Wiring the EUREKA Electric Ignition  (Read 2593 times)
writetomilo
on: June 13, 2011, 10:53:34 am
HELP. It looks simple but cant make it work. Have 65 bullet with new 12V wiring. Putting EUREKA on but want to know where the wires go. DO the go straight onto the coil and ontop of existing wiring.  What happens to the old wire that connected to the original points?
Reply #1 on: June 14, 2011, 08:17:42 pm
  • Global Moderator
Reply #2 on: June 14, 2011, 08:18:57 pm
If you connect one of the wires form the ignition to the old points wire you will NOT lose the kill switch
www.cyclesidecar.com
