The knurled nut at the wheel was a bit loose, and I found that the last 1" or so of the cable seemed a bit dry (not the part that goes into the drive, but the cable itself). I don't know whether it dried out because the nut was loose, or if whoever lubed it at the factory didn't quite get to the end of the cable.
