My 96 Bullet 500
May 25, 2016, 07:49:24 pm
Author Topic: What is this deadend wire in headlight ?  (Read 2776 times)
« on: June 06, 2011, 12:35:36 pm »
There is a grey colored wire behind the headlight, in the nacelle of my G5 that went nowhere - just deadend.  What is this for ?
Okie Enfield
  • RED 2010 C5
Re: What is this deadend wire in headlight ?
« Reply #1 on: June 06, 2011, 03:43:58 pm »
 ;D I-POD port  ;D
jjoe256
« Reply #2 on: June 06, 2011, 03:56:37 pm »
It may be a wire for a parking light.
JesterNT
  • Maintenance is as much art as it is science.
« Reply #3 on: June 06, 2011, 03:57:22 pm »
Does it have a voltage +/- ?
Quando Omni Flunkus Moritati
« Reply #4 on: June 06, 2011, 04:13:53 pm »
Singh, did you check the wiring diagram in the owner's manual?
« Reply #5 on: June 06, 2011, 04:58:06 pm »
I'll bet it's for the little parking light that used to be in the headlamp, I wonder if the Indian domestic models still have it?
drbvac
  • Low as it can go
« Reply #6 on: June 06, 2011, 05:24:58 pm »
The other gray wires in the headlamp go to the pilot lights so the parking idea is probably correct
Dr B
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
« Reply #7 on: June 06, 2011, 06:17:16 pm »
Its the flux capacitance inducer
GSS
« Reply #8 on: June 06, 2011, 09:51:17 pm »
I think you are right. My C5 came with the 7" Minda headlight and the little parking light and this might be it..........
« Last Edit: June 07, 2011, 06:45:18 am by GSS »
2014 GT - Red
2010 C5 - Teal
It's a Jeep thing......
WillW
« Reply #9 on: June 07, 2011, 02:23:48 am »
+1 for the parking light. UK bikes have 7" headlight with a little parking bulb in the side of the reflector.
« Reply #10 on: June 07, 2011, 06:50:16 am »
You mean my G5 is missing a parking bulb  :D !
Nah, I like the idea it is an I-pod line  ;D - Now, I will have to buy an I-pod/pad - those touch thingy's.  They are amazing though.
Thanks to all.
« Last Edit: June 07, 2011, 08:47:46 am by singhg5 »
Sub
  • Bob's Your Uncle
« Reply #11 on: June 07, 2011, 09:14:22 am »
Ohhh, so if that is a switched 12v+  power line, that would be PERFECT place to tap off for my forthcoming headed grips! :) I wonder if it has its own fuse.
Andy
« Reply #12 on: June 07, 2011, 09:35:23 am »
Another one of those little mysteries - like why the switch for four-way hazards isn't connected.
2010 C5 Military - "The Slug"
olhogrider
  • Black C5
  • 2012 C5
« Reply #13 on: June 07, 2011, 12:01:46 pm »
What switch? Pic?
drbvac
  • Low as it can go
« Reply #14 on: June 07, 2011, 02:36:45 pm »
I believe its between the starter button and the stop engin button on the right handgrip.
I put on a Kuryakin rig to hold the throttle in postition while cruising to give my hand a rest so it doesnt fall asleep and was concerned about covering the switch. Then I realized it didnt connect to anythign so who cares ::)
Dr B
