Larger fairing - Side View
May 27, 2016, 09:10:20 pm
Author Topic: C5 on rails  (Read 5484 times)
C5 on rails
« on: June 04, 2011, 03:23:33 pm »
I just put a set of Kenda K265 3.50x18's on my C5, I've never had any handling complaints about my bike, but the improvement over those stock low profile tires is very noticeable, it feels like it's on rails now. I'll never go back to a low profile tire.  :D
« Last Edit: June 05, 2011, 08:21:44 pm by r80rt »
Okie Enfield
  • RED 2010 C5
Re: C5 on rails
« Reply #1 on: June 04, 2011, 03:28:50 pm »
 :o Me likey the look!  :o How much did those run? Any clearance problems? I will probably keep the stocks for awhile longer but those look real nice on that RED C5!  ;D
Re: C5 on rails
« Reply #2 on: June 04, 2011, 03:36:54 pm »
They were around $50 each, They are a Dunlop K70 knock off, I've ran K70's on all my vintage bikes and wanted to try them on the C5 but couldn't find any the right size. No clearence problems.
I found these on sale and thought I'd give them a try, glad I did.
 They look right and handle very well. it did take a bit more weight than I like to balance them but nothing horrible, I'm curious as to how long they will last. I gained nearly an inch in needed tire height on front too. I'm running them at 26psi front 28psi rear.
« Last Edit: June 06, 2011, 01:30:21 pm by r80rt »
Andy
Re: C5 on rails
« Reply #3 on: June 04, 2011, 03:47:46 pm »
Oh, nice.  Like the look of those.
2010 C5 Military - "The Slug"
Okie Enfield
  • RED 2010 C5
Re: C5 on rails
« Reply #4 on: June 04, 2011, 03:48:40 pm »
I use to run Kenda's on my Bajaj and never had an issue with them. I like the look! Keep us informed on the ride.
prof_stack
Re: C5 on rails
« Reply #5 on: June 04, 2011, 04:46:49 pm »
Yeah, they look like "normal" tires that might give my C5 a better sense of stability at higher speeds.  Good.  Thanks.
jjoe256
Re: C5 on rails
« Reply #6 on: June 04, 2011, 06:31:58 pm »
  My G5 has always felt on rails, but I've about worn out my original Avon Ribbed Speedmaster. I've had great luck with IRC. Has anyone tried these:
http://www.motorcycle-superstore.com/3/31/401/19085/ITEM/IRC-GS-11-All-Weather-Front-Tire.aspx
  Visually, the tread is more interesting than the ribbed. I put over 8,000 on another IRC front and it still had plenty left.
« Last Edit: June 04, 2011, 06:41:44 pm by jjoe256 »
Re: C5 on rails
« Reply #7 on: June 04, 2011, 07:52:04 pm »
Interesting!  Same size front and rear?  Are these bias ply tires or radial?
jjoe256
Re: C5 on rails
« Reply #8 on: June 04, 2011, 08:28:21 pm »
Bias, S rated, Tube Type, both 3.25 and 3.50 but 19 inch for G5. There is a 3.50x18,but rear but could service both, different tread:
http://www.motorcycle-superstore.com/3/31/401/19086/ITEM/IRC-GS-11-All-Weather-Rear-Tire.aspx
« Last Edit: June 04, 2011, 08:31:45 pm by jjoe256 »
Re: C5 on rails
« Reply #9 on: June 04, 2011, 08:35:45 pm »
Yes I used the same tire front and rear, 3.50x18's.  It's a Kenda K265 universal bias ply tire. I just pulled a IRC Durotour off the rear, it lasted a whopping 3,600 miles.
http://www.kenda.com.tw/eng/product/mc/k265.htm
« Last Edit: June 05, 2011, 07:29:43 am by r80rt »
Andy
Re: C5 on rails
« Reply #10 on: June 04, 2011, 08:50:23 pm »
WANT!
What tire pressure are you using?
Re: C5 on rails
« Reply #11 on: June 04, 2011, 08:52:00 pm »
prof_stack
Re: C5 on rails
« Reply #12 on: June 04, 2011, 09:15:25 pm »
Wow, "real" m/c tire pressures!   :D
Re: C5 on rails
« Reply #13 on: June 05, 2011, 01:42:59 am »
Indeed!
Makes me wonder.  I like my nimble little bike and the AM26s are good in the wet.  Just wondering more what else is out there now.
Re: C5 on rails
« Reply #14 on: June 05, 2011, 07:17:24 am »
Here is a pic. so you can see how the 3.50 fills the gap on the front fender. According to my non scientific measurements these are the differences in the tires.
3.50x18  25.3"OD - 3.5" wide.
90/90-18   24.4" OD - 3.5" wide.
110/80-18  24.9" OD - 3.9" wide.
