I took the G5 in for a dyno run, the results are attached.
The bike is a 2011 with the English EFI silencer from Nfieldgear, and K&N Filter from DouglasMoto. It has 1550 miles on it. Mickey adjust the idle mixture, but not the speed. I have to slow it down a bit now. He made two runs with it, with no changes between them. The second was probably a bit hotter, The curves were very similar to the earlier posted dyno runs, but this one wasn't as rich, possibly due to the filter. It's a DynoJet dyno.
Since I never had a previous run to compare the mods to, it's impossible to determine the real effects of the options.
