INSTRUCTIONS
FRONT DISC BRAKE CONVERSION KIT #Z90547
1. The front disc brake conversion kit requires a bit of mechanical knowledge; we recommend you have a service manual to assist with this conversion. You will also be required to lace your own wheel or have a qualified mechanic do this for you. The caliper and master cylinder are filled prior to shipment, you should not have to bleed the system after completion but it won’t hurt to do so.
2. You will have to remove and keep together the speedo drive assembly, the one axle nut, bearings (if not damaged from the removal out of the old hub, we recommend the purchase of new wheel bearings), and the spindle. All the other components will not be used on the conversion.
3. You will now need to remove the rim band from the drum brake system. With the new hub, spokes and nipples start lacing the rim band to the new hub. IF YOU HAVE NEVER LACED A WHEEL, WE RECOMMEND THAT YOU BRING IT TO A QUALIFIED MECHANIC TO HAVE THIS DONE!
4. With the wheel laced you will install the bearings and the spindle. First install one bearing on the spindle (install bearing on the short end first) this will be the disc side of the hub. With the bearing on the spindle install the assembly into the hub (disc side). The bearing will have to be driven in far enough that it allows room for the seal. The seal will only seat half the depth of itself. Now install the bearing on the speedo drive side (RH), this will be driven in to a depth of about 1/2". If this is not seated far enough you will not be able to install the speedo drive assembly (the spacer will keep the speedo drive assembly to high for it to lock into the two slots on the hub). Next place the straight spacer on the speedo drive. Place the speedo drive assembly on and rotate it until you feel it lock into the slots and install the axle nut. On the disc side, place the stepped spacer on the spindle and check to see if the spacer covers the threads on the spindle (smaller diameter of spacer goes towards the bearing). If the spacer does not cover all the threads, use the large shims to space the wheel spacer so it covers the threads.
5. Now install the hub adapter plate to the hub (this is for the rotor to attach to the hub) with the six hex flange bolts (M8 x 25), use blue LOCTITE on the six adapter plate bolts!
6. Next install the rotor to the adapter plate with the six button head bolts keeping the etching on the rotor facing outwards. Use blue LOCTITE on the button head bolts!
7. Install the wheel on the bike (rotor goes on the LH side) and locate the standoff for the drum brake face plate located on the LH fork lower. With the wheel mounted (DO NOT SPIN THE WHEEL) you will need to check the clearance of the adapter plate flanged hex bolts and the drum brake plate standoff. You will need to file some of the standoff away to get the correct clearance. Be sure to give yourself about 1/8” of actual clearance.” BE WARE THAT IF YOU FILE THE WHOLE STANDOFF YOU MAY EXPIRENCE SOME OIL SEAPAGE”.
8. Now install the caliper bracket on the fork lower, you will notice the short section that angles out. This is the top and it will point towards the motor. You will need to replace the stud that the brake cable stays to and replace it with the short stud to install the caliper bracket. Use the two acorn nuts and the supplied two internal teeth lock washers.
9. With the two black spacers and two M8 x 35 flange bolts mount the caliper to the bracket. Here you will need to pay close attention on the alignment of the caliper to rotor. If there is noticeable binding it may be necessary to file the standoffs that the caliper bracket is mounted to. This may not be parallel to the rotor (may be at a slight angle to the rotor). File it little by little to ensure you don’t over file the standoffs.
10. Once you have the caliper fitted (Parallel to the rotor) you will need to space the caliper with the shims provided (four .05mm, four 1.0mm) for the caliper and rotor alignment. The wheel should spin with minimal drag of the pads, if there is significant drag after squeezing the brake a few times you will need to shim it more.
11. Now you will need to mount the master cylinder to the handle bar. Be sure that you route the brake line under the triple tree and secured via cable loops supplied in the kit. The two cable loops will mount to the lower pinch bolts of the triple tree on the back side. Be sure to inspect the brake line for possible hazards, being pinched or contact with moving parts. Use the supplied jumper harness to wire the front brake light in.
12. Now you will need to line up the LH center fender stay to the caliper bracket. Mark the fender stay 1/2" below the top hole on the caliper bracket and mark the fender stay where the hole is to be drilled. This is for mounting the fender stay due to the caliper bracket is in its original place.
13. Mount the fender stay with the M8 x 16 bolt and nut supplied in the kit to the caliper bracket.
Caliper bracket: x 1 Brake switch jumper harness: x 1
Caliper brkt bolt: x 2 Caliper shim, .05mm: x 4
RH wheel spacer: x 1 Internal lock washer: x 3
LH wheel spacer: X 1 Caliper shim, .10mm: x 4
Wire loop: x 2 Caliper spacer/bracket: x 2
Fender stay bolt: X 1 Wheel spoke long: x 20
Caliper bracket stud: x 1 Wheel seal: x 1
Hub adapter plate bolt: X 6 Wheel spoke short: x 20
Wheel shim, .05mm: x 4 Fender stay nut: x 1
Rotor bolt: x 6
Note: Be sure to check and double check all fasteners and hardware for tightness and fitment and function. Turn the handle bars fully to both RH and LH and watch for the brake line to ensure it does not get pinched or caught in moving parts. Also check the brake line for proper slack, the brake line should have a small amount of slack when front suspension is extended.
Take the bike for a test ride, after test ride check the rotor for any discoloration. This would indicate that the caliper and rotor may not be aligned correctly or the caliper is hanging up. Check the alignment of caliper and rotor, check the caliper and slide pins for binding, if its binding you may need to add more shims or take out a shim.
Note: Use approved and accepted shop practices and all applicable safety gear and practices when installing these products on your motorcycle. These instructions assume a certain level of mechanical competency, such as the ability to use hand and power tools as well as basic mechanical experience. If you lack the tools or experience to install these accessories after a review of the instructions, please consult a professional or your Royal Enfield dealer. Classic Motorworks or Royal Enfield assumes no liability for installation or fitness for use of these products.
