2010 G5 Deluxe
21 Guests, 1 User
Blairio
February 11, 2016, 11:53:25 pm
Author Topic: Oil in Airbox fix  (Read 3004 times)
Re: Oil in Airbox fix
« Reply #15 on: May 29, 2011, 07:26:46 am »
Centerstand.
nigelogston@gmail.com
« Reply #16 on: May 29, 2011, 07:43:08 am »
Thanks
GreenRE
« Reply #17 on: May 29, 2011, 11:21:03 am »
Does this KnN crankcase filter have a one-way valve.
« Reply #18 on: May 29, 2011, 01:58:26 pm »
No, it's just a filter.
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
« Reply #19 on: May 29, 2011, 11:16:06 pm »
Does it need a one-way valve?
r80rt, ever have any oil seeping out of yours? I don't have this problem now, but I guess some others do (likely from over filling the oil).
« Reply #20 on: May 29, 2011, 11:57:15 pm »
A one way valve is nice but that's to keep partial vacuum in the crankcase which adds a bit of power.  It's  the same reason it's hooked to the airbox, partial vacuum (and it burns any vapors for emissions).  It's not required.
Some filters weep on some bikes, some don't.  If yours does you can usually sort it by running a longer line and setting the filter higher.  That way if it burps a little oil up it doesn't make it to the top and just runs back down.
BRADEY
« Reply #21 on: May 30, 2011, 12:52:20 am »
Why not check the "Old English Arragement" on the Iron barrel REs...
It has a separate "canister, attached at one end to the engine and the other to the air filter box. Any oil that made to the top would be collected in the canister (oil catch can) and air would be released into the air filter box. It was virtually bullet proof.
Cheers.
« Reply #22 on: May 30, 2011, 07:03:27 am »
The C5 doesn't have a one way valve so I don't think it's needed. I used a long hose and went up as high as possible then I turned it back down a few inches to keep any water from going down the hose, no sign of any oil from it.
The UCE has a breather chamber bult into the engine right hand side cover, it's a hidden catch can that takes care of any normal oil and lets only vapor vent out. It's a pretty cool design, if oil gets to the air box it's because the bike is over filled.
Get yourself a factory service manual and parts manual, they will answer a lot of questions ;)
« Last Edit: May 30, 2011, 09:03:39 pm by r80rt »
PAndy
« Reply #23 on: June 27, 2011, 04:46:06 pm »
I've been very methodical about filling to the correct level, I'm about halfway between the two lines (approx. a quarter full on the entire sightglass) and I had the worse oil vomit to date last night.
It only occurs when I'm at highway speed for a sustained period and it seems to be worse when the engine is colder but it is still causing quite a mess.
Does anyone else drive at highway speeds (~70 mph) for a significant period of time (20+ mins)?
« Reply #24 on: June 27, 2011, 05:08:54 pm »
I do, and no problems.  One thing to try, fill to just the bottom line.  Then get the engine nice and hot and see where it is.  You want it at the top line (middle of the site glass) when it's hot.  For whatever reason the oil is higher when the engine is hot than when it is cold.
PAndy
« Reply #25 on: June 27, 2011, 05:18:28 pm »
That's how I fill it, to the bottom line, run for ~10 minutes, then fill to halfway between lines, so if anything I'm a little underfilled, but nevertheless oil vomit.
« Reply #26 on: June 27, 2011, 05:20:57 pm »
Have your dealer check it out.
« Reply #27 on: June 27, 2011, 09:39:59 pm »
reduce the oil level to the bottom of the line
Tri750
  • Big Al
« Reply #28 on: June 27, 2011, 10:56:42 pm »
low is good, good is low.
The owners manual says to mid-way it.
we tell new owners over and over to leave it where we set it
at PDI.
so far, just I of our folks overfilled and knew immediately
what happened. no drama.
Current bikes:
'71 BMW R75/5 racer
'73 Kaw Z1 racer
'77 Tri 750 Bonneville
'99 BMW R1100RT
« Reply #29 on: June 27, 2011, 11:24:45 pm »
If you measure what comes out, replace it with about the same.  My C5 level is at the upper line and so far there has been no oil in the box.  But perhaps after an aggressive ride it might be.
Sounds like a challenge!   :D
