Two hours of dyno room time. The shop paid for one of them.
The backstory: With the upswept muffler installed, the C5 has been popping, pooting, and POWing with backfires. Performance has been better as the bike is freer breathing. The K&N air filter also helps. But the backfires are irritating.
Ducati/RE Seattle wanted to see if a dynojet or powercommander might work and also wanted to sniff the gases for more information.
Here's a brief summary. I still don't understand all of it. But eventually...
- The upswept muffler has a baffle in it that prevents the sniffer rod to get far enough inside to be useful.
- The fuel/air mix is rich for higher rpm's. I saw the ratios but don't yet have the printout. It is better to have it richer than leaner.
- Max HP was 19 under normal load. With the airbox door open it went up 5% to 20HP.
- I saw the graphs and will post the jpeg of them when they email them to me.
- He said it topped out at 90mph when the rev limiter kicked in. That was measured with the dyno equipment, not the speedometer.
- Marty the tech said that a larger air filter would let in more air that should increase HP a little. r80rt's system seems like a good idea.
- They removed the throttle body and checked HP with no tube and got nice results for high rpm's but horrible low rpm results.
So, it cost me $100 to find out that they can't do anything about the system until they learn more about how to defeat the O2 sensor and not have an error code pop up in the computer system of the bike.
I'll post more details and comments, plus HP/torque graphs when they are ready.
