Author Topic: c5 military sticker removal  (Read 1747 times)
kingrock
  • 2010 c5 military/ The green Goddess
on: May 25, 2011, 02:27:16 am
Looking to remove tank decal and air intake ones as well. But it appears the tank is dull coated. I'm replacing them with stars and vet decals. Any suggestions on how.
Sub
  • Bob's Your Uncle
  • 2010 Black Bullet C5
Reply #1 on: May 25, 2011, 03:56:45 am
Use a big sticker background that covers the oem one?! They're under clearcoat so its going to be a pita to remove, and messy.
GSS
Reply #2 on: May 25, 2011, 04:16:10 am
It will be messy. Maybe wet 2000 grit sandpaper to gently cut through the clear coat on an edge and see if it will start to peel off? I wouldn't apply heat to the gas tank, but parking it in direct sunlight may help soften up the adhesive....hopefully it is not a permanent methacrylate type of chemical. .
2022 Continental GT 650 Dux Deluxe
2019 Himalayan Snow
2019 Interceptor 650 - Chrome...off the first boat!
Previous REs:
2021 Meteor 350 Supernova Blue
2014 Continental GT 535 - Red...lowest VIN off the first boat!
2010 Classic 500 - Teal Chrome
Andy
Reply #3 on: May 25, 2011, 01:57:19 pm
I took the decal off the rear fender because it was off centre and looked natty.
When you get them off, you'll have a shinier (un-clearcoated) surface underneath and a ridge where they used to end.  You'll need to refinish the whole tank.
2010 C5 Military - "The Slug"
kingrock
Reply #4 on: May 26, 2011, 03:11:13 am
Yea, I'm thinking 220. Scrape off the stickers. Sand and feather. Need to get the oem paint and possibly the flat clearcoat. Any ideas where? Thanks
drbvac
  • Low as it can go
Reply #5 on: May 27, 2011, 12:25:52 am
You may as well take off the tank - re do it all the way you want it and clear coat the entire thing or ir will always look like it was done in pieces - or go over the old decals and just re-coat the tank.
Dr B
